Saltar al contenido principal
Vivitar DVR 781HD Waterproof Case Lens Cover Replacement
Qué necesitas
  1. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement, Waterproof Case Lens Cover: paso 1, imagen 1 de 1
    • Place waterproof case on flat surface, with the lens cover facing up.
  2. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: paso 2, imagen 1 de 2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: paso 2, imagen 2 de 2
    • Remove the six 4.5mm Phillips #00 screws from the black lens cover trim.
  3. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: paso 3, imagen 1 de 2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: paso 3, imagen 2 de 2
    • While holding the black lens cover trim tight to the case, flip the case over so that the lens cover is rested on your work surface.
  4. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: paso 4, imagen 1 de 2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: paso 4, imagen 2 de 2
    • Apply pressure to the lens cover with your thumb, and use your other fingers to pull up on the case, separating the lens and lens trim from the case.
  5. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: paso 5, imagen 1 de 2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: paso 5, imagen 2 de 2
    • There is a small plastic key on the black bezel that aligns it to the case. Be sure to line this up during reassembly.
Conclusión
Una persona más ha completado esta guía.
Jordan Baum
Miembro Desde 02/13/16
355 Reputación
2 Guías creadas
Equipo
IUPUI, Team 54-6, Wilson Spring 2016 Miembro de IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Miembros
10 Guías creadas
Un comentario
Hello, do you know where I can acquire a replacement water proof case for my Vivitar DVR 787 HD action camcorder?
Andrew Hinsley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,258
