Saltar al contenido principal
Uninstalling an Electric Water Heater
Qué necesitas
  1. Uninstalling an Electric Water Heater, Water Heater: paso 1, imagen 1 de 1
    • At the breaker box, locate the breaker for the water heater. Switch the breaker bar to the off position.
    • Using a multimeter, check the line voltage at the water heater. The multimeter should read "0 VAC."
  2. Uninstalling an Electric Water Heater: paso 2, imagen 1 de 2 Uninstalling an Electric Water Heater: paso 2, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the access panel (or panels) to access the thermostat and element.
    • Some electric water heater models may have only one access panel, located near the bottom of the tank. Some may have two— both an upper and lower access panel.
    • Set aside the access panel cover and screws. Remove the insulation to expose the wires, thermostat, and element.
    • Disconnect the wiring from the electrical components in the panel.
  3. Uninstalling an Electric Water Heater, Draining the tank: paso 4, imagen 1 de 1
    • Attach a hose to the drain valve located at the bottom of the tank, near the lower access panel. Place the other end of the hose in a safe location for the water to drain.
    • Open the drain valve on the water heater by turning it counter-clockwise.
    • Once you have a steady flow of water coming out of the hose, slowly close the cold water valve to the water heater by turning it clockwise.
    • If the water flow slows down, you can open a sink or tub faucet to help the tank drain quicker.
  4. Uninstalling an Electric Water Heater: paso 5, imagen 1 de 1
    • Using adjustable pliers, disconnect the water lines from the tank.
    • If the lines are glued in place, you will need to use a steel wire saw to disconnect the water line.
  5. Uninstalling an Electric Water Heater: paso 6, imagen 1 de 2 Uninstalling an Electric Water Heater: paso 6, imagen 2 de 2
    • Using a pipe wrench, detach all remaining pipes from the tank.
  6. Uninstalling an Electric Water Heater: paso 7, imagen 1 de 1
    • Remove the water tank.
    • The tank will have sediment and some water in it. It will be heavy and require at least 2 people to move it safely.
    • To install a new water heater, follow the manufacturer's installation instructions included with the new appliance.
Conclusión
To install a new water heater, follow the manufacturer’s installation instructions provided with the new water heater.
2 personas más completaron esta guía.
Un comentario
If you have enough assistance to transport the unit outside the house, taking apart an old water heater is simple. Components, mounting hardware, and other aspects of a water heater can all be removed independently. Nonetheless, it takes strength to pull the old water from its place and move it outside for proper disposal.
Juliet Cyrus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 130
Todo El Tiempo: 4,716
