Saltar al contenido principal
Track Cleats Spikes Replacement
Qué necesitas
  1. Track Cleats Spikes Replacement, Spikes: paso 1, imagen 1 de 1
    • Place a cleat wrench over the spike and rotate it clockwise until it locks in place.
  2. Track Cleats Spikes Replacement: paso 2, imagen 1 de 1
    • Rotate the wrench counterclockwise 4 to 5 times, or until the spike detaches from the sole.
  3. Track Cleats Spikes Replacement: paso 3, imagen 1 de 1
    • Repeat Steps 1-2 to remove the remaining spikes.
  4. Track Cleats Spikes Replacement: paso 4, imagen 1 de 1
    • Clean the sole and screw holes using dish soap, a sponge or cloth, and warm water.
  5. Track Cleats Spikes Replacement: paso 5, imagen 1 de 1
    • Dry the shoe with a towel, and allow the sockets time to fully dry before installing new spikes.
    • Do not screw spikes into wet or damp sockets as the spikes will likely rust, making them extremely difficult, if not impossible, to remove in the future.
  6. Track Cleats Spikes Replacement: paso 6, imagen 1 de 1
    • Grab the new spike and place the thread into the screw hole. Screw the spikes clockwise back in place.
    • Screw the spikes until tight, then rotate another 1/16 of an inch. Be sure not to over-tighten the spikes.
  7. Track Cleats Spikes Replacement: paso 7, imagen 1 de 1
    • Repeat Step 6 for the remaining spikes.
  8. Track Cleats Spikes Replacement: paso 8, imagen 1 de 1
    • Make sure all the spikes are tight, and then proceed to test out shoes on an appropriate surface.
    • Always test new spikes before racing.
Conclusión
Have fun running!
Una persona más ha completado esta guía.
Gabriel Williams
Miembro Desde 02/28/22
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 665
