Saltar al contenido principal
Top Cover Removal
Qué necesitas
  1. Top Cover Removal, Remove film door: paso 1, imagen 1 de 1
    • Push down the latch to release the film door.
  2. Top Cover Removal, Remove top cover screws: paso 2, imagen 1 de 3 Top Cover Removal, Remove top cover screws: paso 2, imagen 2 de 3 Top Cover Removal, Remove top cover screws: paso 2, imagen 3 de 3
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
  3. Top Cover Removal, Remove top cover screws: paso 3, imagen 1 de 3 Top Cover Removal, Remove top cover screws: paso 3, imagen 2 de 3 Top Cover Removal, Remove top cover screws: paso 3, imagen 3 de 3
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
  4. Top Cover Removal, Lift top cover: paso 4, imagen 1 de 1
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
  5. Top Cover Removal, Access flash connections: paso 5, imagen 1 de 2 Top Cover Removal, Access flash connections: paso 5, imagen 2 de 2
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
  6. Top Cover Removal, Discharge flash capacitors: paso 6, imagen 1 de 1
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  7. Top Cover Removal, Disconnect right flex cable: paso 7, imagen 1 de 1
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
  8. Top Cover Removal, Disconnect left flex cable: paso 8, imagen 1 de 1
    • Desolder the red wire.
  9. Top Cover Removal, Desolder flash connections: paso 9, imagen 1 de 2 Top Cover Removal, Desolder flash connections: paso 9, imagen 2 de 2
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
  10. Top Cover Removal, Desolder the flash flex cable: paso 10, imagen 1 de 2 Top Cover Removal, Desolder the flash flex cable: paso 10, imagen 2 de 2
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
Conclusión
Sam Gustafson
Miembro Desde 09/01/22
3,350 Reputación
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 117
