Saltar al contenido principal
Tesla Model 3 Keyfob Battery Replacement
Qué necesitas
Resumen del Video
  1. Tesla Model 3 Keyfob Battery Replacement, Prep: paso 1, imagen 1 de 1
    • Prepare a surface to work on (ensure it's won't damage the piano black exterior coating)
    • Gather your key fob and a small plastic spudger
  2. Tesla Model 3 Keyfob Battery Replacement, Battery Replacement: paso 2, imagen 1 de 3 Tesla Model 3 Keyfob Battery Replacement, Battery Replacement: paso 2, imagen 2 de 3 Tesla Model 3 Keyfob Battery Replacement, Battery Replacement: paso 2, imagen 3 de 3
    • Using a small pry tool, gently press into the small indent near the front of the key fob while pressing up to pop off the battery cover.
    • Remove the coin-cell battery type CR2032 by prying upwards in the small recess
    • Insert a fresh CR2032 coin cell battery being sure to match the correct polarity of the original
    • If all you want to do is replace the battery, stop here. Otherwise check out my other guide for a full teardown!
Conclusión
Una persona más ha completado esta guía.
IZ Labs
Miembro Desde 08/13/17
217 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 16
Todo El Tiempo: 83
