Saltar al contenido principal
Stuffed Animal Safety Eye Replacement
Qué necesitas
  1. Stuffed Animal Safety Eye Replacement, Safety Eye: paso 1, imagen 1 de 1
    • Be sure to keep the eye that fell out and the backing or buy a new one.
    • New safety eyes are pretty inexpensive and easy to find.
    • Do not put the backing on the eye until it's in place.
  2. Stuffed Animal Safety Eye Replacement: paso 2, imagen 1 de 1
    • The eyes on the face are located in or close to a seam that holds it in place.
    • Use your scissors to open the seam. Be very careful to cut the thread and not the fabric.
    • Make the opening of the seam so it fits the replacement eye.
  3. Stuffed Animal Safety Eye Replacement: paso 3, imagen 1 de 1
    • Use this new hole to put the eye back in its original position.
  4. Stuffed Animal Safety Eye Replacement: paso 4, imagen 1 de 2 Stuffed Animal Safety Eye Replacement: paso 4, imagen 2 de 2
    • Insert the safety eye in the original position.
    • Before putting on the backing make sure it's symmetrical to the other eye.
  5. Stuffed Animal Safety Eye Replacement: paso 5, imagen 1 de 3 Stuffed Animal Safety Eye Replacement: paso 5, imagen 2 de 3 Stuffed Animal Safety Eye Replacement: paso 5, imagen 3 de 3
    • When the eye is in place put the backer on the eye from the inside of the plushie.
    • Use the hole of the seam we opened to do that.
    • Press very hard until the eye and the back click together.
  6. Stuffed Animal Safety Eye Replacement: paso 6, imagen 1 de 1
    • Sew the seam back up using a simple stitch.
    • Begin the stitches from the inside out so they are not visible, then fasten off the thread at the end of the seam.
    • The thread should be the same color as your plushie.
  7. Stuffed Animal Safety Eye Replacement: paso 7, imagen 1 de 1
    • Take a pin and poke at the fur carefully to make it fluffy again.
    • Doing this will ensure the eye doesn't look like it's popping out.
  8. Stuffed Animal Safety Eye Replacement: paso 8, imagen 1 de 1
    • Repeat the previous step all around the eye until it looks seamless.
    • And your done!
Conclusión
To reassemble your device, follow these instructions in the order suggested.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 51
Todo El Tiempo: 2,373
