Saltar al contenido principal
Sprinkler Head Replacement
Qué necesitas
  1. Sprinkler Head Replacement, Sprinkler Head: paso 1, imagen 1 de 1
    • Turn off the water supply to the sprinklers.
    • This process will vary depending on your sprinkler controller.
  2. Sprinkler Head Replacement: paso 2, imagen 1 de 1
    • Find where the water supply feeds the sprinkler system and close the valve in the event of emergency or unforeseen circumstances.
  3. Sprinkler Head Replacement: paso 3, imagen 1 de 1
    • Dig a hole down to the base of the sprinkler head.
    • Be careful to avoid puncturing the sprinkler line.
  4. Sprinkler Head Replacement: paso 4, imagen 1 de 1
    • Using your hand or a gardening trowel, finish digging so that the sprinkler head is fully visible and is clear of dirt and debris.
  5. Sprinkler Head Replacement: paso 5, imagen 1 de 2 Sprinkler Head Replacement: paso 5, imagen 2 de 2
    • Unscrew the sprinkler head from the line it is attached to.
    • If is loose enough you may not need pliers.
  6. Sprinkler Head Replacement: paso 6, imagen 1 de 2 Sprinkler Head Replacement: paso 6, imagen 2 de 2
    • Coat the threads of the water line with teflon tape to avoid leaking.
  7. Sprinkler Head Replacement: paso 7, imagen 1 de 2 Sprinkler Head Replacement: paso 7, imagen 2 de 2
    • Using your hand, screw the new sprinkler head on over the teflon tape.
    • Once the sprinkler head is hand tight, use pliers to tighten it by another half turn.
  8. Sprinkler Head Replacement: paso 8, imagen 1 de 1
    • Fill the hole in and pack it down to avoid unwanted movement of the new sprinkler head.
  9. Sprinkler Head Replacement: paso 9, imagen 1 de 1
    • Turn the sprinkler system on.
  10. Sprinkler Head Replacement: paso 10, imagen 1 de 1
    • Twist the top of the sprinkler until it is aimed where you want it.
  11. Sprinkler Head Replacement: paso 11, imagen 1 de 1
    • Use a flat head screwdriver to adjust the flow of water if needed.
    • Turning right decreases the water flow. Turning left increases the water flow.
Conclusión
Enjoy your green lawn and water savings.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 31
Todo El Tiempo: 398
