Saltar al contenido principal
Sony Cyber-shot DSC-WX100 Outer Casing Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: paso 1, imagen 1 de 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: paso 2, imagen 1 de 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: paso 3, imagen 1 de 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: paso 3, imagen 2 de 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: paso 3, imagen 3 de 3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: paso 4, imagen 2 de 2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool to gently release the two indicated tabs.
Conclusión
2 personas más completaron esta guía.
Matthew
Miembro Desde 03/18/15
583 Reputación
4 Guías creadas
Equipo
Un comentario
Where I can buy the Outer Casing..¿??
ING CHARLY - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 20
Todo El Tiempo: 856
