Saltar al contenido principal
Sony Cyber-shot DSC-W55 Front Case Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W55 Front Case Replacement, Battery: paso 1, imagen 1 de 2 Sony Cyber-shot DSC-W55 Front Case Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Front Case Replacement: paso 2, imagen 1 de 2 Sony Cyber-shot DSC-W55 Front Case Replacement: paso 2, imagen 2 de 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Front Case Replacement, Back Case: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-W55 Front Case Replacement, Back Case: paso 3, imagen 2 de 2
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Front Case Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-W55 Front Case Replacement: paso 4, imagen 2 de 2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Front Case Replacement: paso 5, imagen 1 de 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Front Case Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-W55 Front Case Replacement: paso 6, imagen 2 de 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 Front Case Replacement, Front Case: paso 7, imagen 1 de 1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Front Case Replacement: paso 8, imagen 1 de 3 Sony Cyber-shot DSC-W55 Front Case Replacement: paso 8, imagen 2 de 3 Sony Cyber-shot DSC-W55 Front Case Replacement: paso 8, imagen 3 de 3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
Conclusión
Una persona más ha completado esta guía.
Andrew Carter
Miembro Desde 10/11/10
202 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-20, Regan Fall 2010 Miembro de Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 3,404
