Saltar al contenido principal
Sony Cyber-shot DSC-P52 LCD Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-P52 LCD Replacement, Outer Case: paso 1, imagen 1 de 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 LCD Replacement: paso 2, imagen 1 de 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 LCD Replacement: paso 3, imagen 1 de 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 LCD Replacement: paso 4, imagen 1 de 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 LCD Replacement: paso 5, imagen 1 de 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 LCD Replacement: paso 6, imagen 1 de 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 LCD Replacement: paso 7, imagen 1 de 1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 LCD Replacement, Sony Cyber-shot DSC-P52 Removing Ribbon Cables: paso 8, imagen 1 de 1
    • Unclip the ribbon cable shown the in picture.
    • Some ribbon cables do not have a clip holding them in.
  9. Sony Cyber-shot DSC-P52 LCD Replacement: paso 9, imagen 1 de 1
  10. Sony Cyber-shot DSC-P52 LCD Replacement, LCD: paso 10, imagen 1 de 1
    • Remove 7 Screws to remove plate and expose LCD screen.
  11. Sony Cyber-shot DSC-P52 LCD Replacement: paso 11, imagen 1 de 1
    • Remove LCD plate to expose LCD components and ribbon cables
  12. Sony Cyber-shot DSC-P52 LCD Replacement: paso 12, imagen 1 de 1
    • Check connection of LCD to cables
    • If cables are intact, disconnect cables and replace LCD with new part
  13. Sony Cyber-shot DSC-P52 LCD Replacement: paso 13, imagen 1 de 1
    • Repeat steps in reverse order to reassemble the camera
Conclusión
Mark
Miembro Desde 01/11/11
13 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 3-43, Regan Winter 2011 Miembro de Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Miembros
20 Guías creadas
Un comentario
I don’t know the cause of my camera not turning on.
Smgmc64 Productions - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 2,505
