Saltar al contenido principal
Sony Cyber-shot DSC-HX90V Battery Replacement
  1. Sony Cyber-shot DSC-HX90V Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the camera is turned off prior to the removal of the battery.
    • Place the camera upside down with the top sitting on the flat surface.
    • Using your fingers, slide the door lock to the unlock position.
  2. Sony Cyber-shot DSC-HX90V Battery Replacement: paso 2, imagen 1 de 1
    • Open the battery compartment door.
    • Remove the battery from the compartment by turning the camera upside down.
    • Insert the new battery into the compartment matching the positive battery lead to the positive terminal and the negative battery lead to the negative terminal on the camera.
Conclusión
2 personas más completaron esta guía.
Marin Rusinov
Miembro Desde 02/02/17
853 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 43
Todo El Tiempo: 2,527
