Saltar al contenido principal
Sony Cyber-Shot DSC-W830 Button Board Replacement
Qué necesitas
  1. Sony Cyber-Shot DSC-W830 Button Board Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Button Board Replacement: paso 2, imagen 1 de 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Button Board Replacement: paso 3, imagen 1 de 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: paso 4, imagen 1 de 3 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: paso 4, imagen 2 de 3 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: paso 4, imagen 3 de 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Button Board Replacement: paso 5, imagen 1 de 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: paso 5, imagen 2 de 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: paso 5, imagen 3 de 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Button Board Replacement: paso 6, imagen 1 de 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: paso 6, imagen 2 de 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: paso 6, imagen 3 de 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: paso 7, imagen 1 de 2 Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: paso 7, imagen 2 de 2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 Button Board Replacement: paso 8, imagen 1 de 2 Sony Cyber-Shot DSC-W830 Button Board Replacement: paso 8, imagen 2 de 2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 17-1, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 1,282
