Saltar al contenido principal
Sony Cyber-Shot DSC-S90 Motherboard Replacement
Qué necesitas
  1. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Batteries: paso 1, imagen 1 de 2 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Batteries: paso 1, imagen 2 de 2
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 2, imagen 1 de 1
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Back Case: paso 3, imagen 1 de 2 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Back Case: paso 3, imagen 2 de 2
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 4, imagen 1 de 2 Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 5, imagen 1 de 2 Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 6, imagen 1 de 1
    • Pull apart the back case from the main body of the camera.
  7. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Front Case: paso 7, imagen 1 de 1
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
  8. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 8, imagen 1 de 1
    • Pull apart the front case from the main body of the camera.
  9. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Top/Side Case: paso 9, imagen 1 de 3 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Top/Side Case: paso 9, imagen 2 de 3 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Top/Side Case: paso 9, imagen 3 de 3
    • Release all clips and latches keeping the casing in place using a spudger, opening tool, or screwdriver.
  10. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 10, imagen 1 de 1
    • Now the casing can be removed after all latches have been undone.
  11. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Battery Terminal: paso 11, imagen 1 de 3 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Battery Terminal: paso 11, imagen 2 de 3 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Battery Terminal: paso 11, imagen 3 de 3
    • Disconnect the ribbon cables on top of the battery terminal using a spudger or screwdriver.
  12. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 12, imagen 1 de 1
    • Disconnect the remaining ribbon cable on the side of the camera using a spudger or screwdriver.
  13. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 13, imagen 1 de 1
    • Use a spudger or screwdriver to unhinge the clips. This releases the battery terminal.
  14. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 14, imagen 1 de 1
    • Once the battery terminal is unclipped, pull this ribbon cable out with a spudger or screwdriver to finish freeing the battery terminal.
  15. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 15, imagen 1 de 1
    • Now the battery terminal can be separated from the main body of the camera.
  16. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Motherboard: paso 16, imagen 1 de 3 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Motherboard: paso 16, imagen 2 de 3 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Motherboard: paso 16, imagen 3 de 3
    • Disconnect the three pictured ribbon cables using a spudger or screwdriver.
  17. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 17, imagen 1 de 1
    • Push the clip to the left and lift the motherboard upwards and away from the camera.
  18. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 18, imagen 1 de 2 Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 18, imagen 2 de 2
    • Disconnect the two ribbon cables using a spudger or screwdriver.
  19. Sony Cyber-Shot DSC-S90 Motherboard Replacement: paso 19, imagen 1 de 1
    • Unlatch the clip and lift the motherboard upwards and away from the camera.
Conclusión
Jonathan Arns
Miembro Desde 10/28/19
745 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 261
