Saltar al contenido principal
Sony Cyber-Shot DSC-H1 LCD Screen Replacement
Qué necesitas
  1. Sony Cyber-Shot DSC-H1 LCD Screen Replacement, Back Panel: paso 1, imagen 1 de 1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: paso 2, imagen 1 de 3 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: paso 2, imagen 2 de 3 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: paso 2, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: paso 3, imagen 1 de 2 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: paso 3, imagen 2 de 2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 1
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
Conclusión
Trystan Jasperson
Miembro Desde 03/17/18
231 Reputación
2 Guías creadas
Equipo
Baylor, Team S5-G4, Williams Spring 2018 Miembro de Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 695
