Introducción
This guide will show you how to remove the LCD on the back of the Samsung NX3000. You can also follow this guide to remove the button panel located next to the LCD.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Qué necesitas
Turn the camera upside down. Only remove the lens if you have to in order to access the battery compartment, as dust particles could easily enter the main body and fall onto the delicate sensor.
Slide the button to the left to open the battery compartment.
Push the blue button up to release the battery.
Remove the three 4.3 mm Phillips screws from the bottom of the camera.
Remove the 4.3 mm Phillips screw hiding inside the battery compartment.
To remove the metal shield on the back case, remove the following screws:
Five black 4.2 mm Phillips screws .
Four silver 5.3 mm Phillips screws.
2 personas más completaron esta guía.
