Saltar al contenido principal
SONY Alpha NEX-3N Keypad Replacement
Qué necesitas
  1. SONY Alpha NEX-3N Keypad Replacement, Getting Started: paso 1, imagen 1 de 2 SONY Alpha NEX-3N Keypad Replacement, Getting Started: paso 1, imagen 2 de 2
    • Remove battery and card
  2. SONY Alpha NEX-3N Keypad Replacement, Back Case 1: paso 2, imagen 1 de 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 1: paso 2, imagen 2 de 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 1: paso 2, imagen 3 de 3
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. SONY Alpha NEX-3N Keypad Replacement, Back Case 2: paso 3, imagen 1 de 1
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. SONY Alpha NEX-3N Keypad Replacement, Back Case 3: paso 4, imagen 1 de 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 3: paso 4, imagen 2 de 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 3: paso 4, imagen 3 de 3
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. SONY Alpha NEX-3N Keypad Replacement, LCD assembly: paso 5, imagen 1 de 2 SONY Alpha NEX-3N Keypad Replacement, LCD assembly: paso 5, imagen 2 de 2
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. SONY Alpha NEX-3N Keypad Replacement, LCD Assembly: paso 6, imagen 1 de 3 SONY Alpha NEX-3N Keypad Replacement, LCD Assembly: paso 6, imagen 2 de 3 SONY Alpha NEX-3N Keypad Replacement, LCD Assembly: paso 6, imagen 3 de 3
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. SONY Alpha NEX-3N Keypad Replacement, The LCD assembly: paso 7, imagen 1 de 1
    • The LCD assembly
  8. SONY Alpha NEX-3N Keypad Replacement, Keypad: paso 8, imagen 1 de 3 SONY Alpha NEX-3N Keypad Replacement, Keypad: paso 8, imagen 2 de 3 SONY Alpha NEX-3N Keypad Replacement, Keypad: paso 8, imagen 3 de 3
    • Lift the keypad.
    • Detach FPC
Conclusión
Terrance
Miembro Desde 11/17/09
6,368 Reputación
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 68
