Saltar al contenido principal
Royal Kludge GK64 Keyboard Switch Spring Replacement
Qué necesitas
  1. Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: paso 1, imagen 1 de 2 Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: paso 1, imagen 2 de 2
    • Use a keycap remover to pull your keycap up and off of the keyboard.
    • Remove any keycaps surrounding the one you are working on if you need more space.
  2. Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 2, imagen 1 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 2, imagen 2 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 2, imagen 3 de 3
    • Use the switch puller to pull the desired switch out of your keyboard.
  3. Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 3, imagen 1 de 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 3, imagen 2 de 2
    • Place your switch onto your switch opener, and gently push down.
    • Make sure the switch is securely in place and continue to remove the top housing.
  4. Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 4, imagen 1 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 4, imagen 2 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 4, imagen 3 de 3
    • Use the stem holder to remove the stem, which will reveal the switch spring.
    • Remove the switch spring.
  5. Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 5, imagen 1 de 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 5, imagen 2 de 2
    • Align your new spring with the center of the bottom housing and gently place the switch spring.
  6. Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 6, imagen 1 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 6, imagen 2 de 3 Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 6, imagen 3 de 3
    • To put the stem back, align the stem legs with the metal plate on the switch.
    • Remove the switch from the switch opener.
    • Gently push down onto the housing until you hear a click and both pieces are into place.
  7. Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 7, imagen 1 de 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 7, imagen 2 de 2
    • Align the pins located at the bottom of the switch to the corresponding pin holes in the keyboard.
    • Gently push the switch back into the keyboard.
  8. Royal Kludge GK64 Keyboard Switch Spring Replacement: paso 8, imagen 1 de 1
    • Place the keycap back onto the switch and push down to secure the keycap.
Conclusión
Una persona más ha completado esta guía.
Diksha Sakre
Miembro Desde 09/19/22
228 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 341
