Saltar al contenido principal
Replacing Antenna on Realistic Weatheradio
Qué necesitas
  1. Replacing Antenna on Realistic Weatheradio, Antenna: paso 1, imagen 1 de 1
    • To remove the back panel from the Weather radio, use your index finger and push down on the tab located on the back.
  2. Replacing Antenna on Realistic Weatheradio: paso 2, imagen 1 de 1
    • Use a Phillips 1X80 screwdriver to loosen the screw located on the bottom right of the back panel.
    • Do not attempt to remove the screw because it will not come out.
  3. Replacing Antenna on Realistic Weatheradio: paso 3, imagen 1 de 2 Replacing Antenna on Realistic Weatheradio: paso 3, imagen 2 de 2
    • Once the screw is loose, slowly pull out the antenna until it is completely out.
    • Once the antenna is out, you can replace it with the new one.
    • Do not force the antenna inside and make sure it is coiled all the way down.
Conclusión
After following these steps, the Realistic Weatheradio should be able to work and function normally.
2 personas más completaron esta guía.
Documentos Adjuntos
Matthew
Miembro Desde 07/17/15
136 Reputación
1 Guía escrita
Equipo
Texas Tech, Team 3-5, Rauch SU 2015 Miembro de Texas Tech, Team 3-5, Rauch SU 2015
TTU-RAUCH-SU15S3G5
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 901
