Saltar al contenido principal
Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop
Qué necesitas
  1. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop, CMOS Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is off and has been unplugged from any power source.
    • Flip the laptop over to gain access to ten M2.5 x 6mm flat head screws.
  2. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 2, imagen 1 de 3 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 2, imagen 2 de 3 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 2, imagen 3 de 3
    • Use a Phillips #0 screwdriver to unscrew all the screws.
    • If you have another screwdriver that fits you can use that as well.
  3. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 3, imagen 1 de 2 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 3, imagen 2 de 2
    • Gently pry open the bottom cover of the laptop.
    • If this is the first time you are opening the laptop it might be harder to separate.
    • If it seems to be stuck at any point DO NOT pull harder you may have forgotten one screw.
  4. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 4, imagen 1 de 3 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 4, imagen 2 de 3 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 4, imagen 3 de 3
    • You need to unplug the battery to make sure that you don't get any potential static shock when you unplug any other component.
    • Lightly shake the connector to disconnect.
  5. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 5, imagen 1 de 2 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 5, imagen 2 de 2
    • Use a spudger or plastic opening tool to pry under the battery, and push forward to pop it free.
    • Be gentle when pushing to avoid potential damage to the battery holder, as your tool may slip.
  6. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 6, imagen 1 de 2 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 6, imagen 2 de 2
    • Place the new battery in by placing it over the holder and lightly pressing down.
  7. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 7, imagen 1 de 2 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 7, imagen 2 de 2
    • Reconnect the battery connector by gently pushing it in until you barely see the white.
  8. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 8, imagen 1 de 3 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 8, imagen 2 de 3 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: paso 8, imagen 3 de 3
    • Re-screw back on the cover.
    • The cover will snap back on as you screw on more screws.
Conclusión
When you turn back on the laptop you will have to redo your BIOS settings.
Brayden Keltz
Miembro Desde 09/04/23
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 168
