Saltar al contenido principal
Repairing Internet Explorer Crashes
Qué necesitas
  1. Repairing Internet Explorer Crashes, Restore Advanced Application Settings: paso 1, imagen 1 de 1
    • Restore the advanced application settings including the ActiveX Filtering and dialog Pop-Up box settings. You’ll be prompted to remove the personal configurations as well. Check-up that box in order to successfully restore all the settings.
    • Close all other applications and open Internet Explorer.
    • Click Tools -> Internet Options.
    • Click Reset button after checking-up the “Delete personal settings” checkbox.
  2. Repairing Internet Explorer Crashes, Filter Malfunctioning Extensions: paso 2, imagen 1 de 1
    • Filter the malfunctioning extensions. Disable all the extensions which are not functioning properly. The list of all extensions is displayed in a dialog box after performing the steps given below:
    • First show the menu bar by pressing the Alt key of your keyboard.
    • Click Tools -> Manage Add-Ons.
    • Set Show -> All add-ons.
    • Filter unwanted extensions including those not working properly.
  3. Repairing Internet Explorer Crashes, Check Internet DNS Configs: paso 3, imagen 1 de 1
    • The Internet DNS Configurations might have been changed. Incorrect DNS configurations are one of the reasons behind this issue.
    • Press the Windows Key and X keys simultaneously, and then select the Command Prompt (Admin).
    • Type below commands one by one and press ENTER at the end of each command: • ipconfig /flushdns • ipconfig /registerdns • ipconfig /release
    • Exit Command Prompt and then reboot your PC.
    • A Troubleshooter tool automatically detects and repairs the Internet Explorer crashes problem. All you’ve to do is-
    • Download the tool called ZombieSoftFix.
    • Install the program on your PC.
    • Follow the on-screen instructions until your problem is completely fixed.
  4. Repairing Internet Explorer Crashes, Uninstall & Reinstall it again: paso 5, imagen 1 de 1
    • Some IE files can be corrupt. Uninstalling and reinstalling the same will fix the issue.
    • Insert the Windows OS disc.
    • Press Windows Key and X simultaneously.
    • Click Programs and Features -> Turn Windows features on or off.
    • Uninstall IE and reinstall it again. A system reboot requires.
Conclusión
8 personas más completaron esta guía.
VikasMedhekar
Miembro Desde 12/10/14
906 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 22
Todo El Tiempo: 1,888
