Saltar al contenido principal
Repair Loose Floorboard Carpet in Vehicle
Qué necesitas
  1. Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: paso 1, imagen 1 de 2 Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: paso 1, imagen 2 de 2
    • Pull back detached carpet from the floorboard to determine how much carpet is detached.
  2. Repair Loose Floorboard Carpet in Vehicle: paso 2, imagen 1 de 2 Repair Loose Floorboard Carpet in Vehicle: paso 2, imagen 2 de 2
    • Apply a generous layer of spray adhesive to floorboard.
    • Wear a mask to prevent inhalation of fumes.
    • Wear gloves to prevent the adhesive from sticking to your hands.
    • Perform repair in a well ventilated area.
  3. Repair Loose Floorboard Carpet in Vehicle: paso 3, imagen 1 de 1
    • Allow 15-30 seconds for adhesive to dry before attaching carpet to floorboard.
  4. Repair Loose Floorboard Carpet in Vehicle: paso 4, imagen 1 de 2 Repair Loose Floorboard Carpet in Vehicle: paso 4, imagen 2 de 2
    • Apply carpet to floorboard firmly using hands.
    • This step needs to be repeated until carpet is in place with no wrinkles or bulges.
  5. Repair Loose Floorboard Carpet in Vehicle: paso 5, imagen 1 de 2 Repair Loose Floorboard Carpet in Vehicle: paso 5, imagen 2 de 2
    • Use a plastic squeegee to tuck the corner of the carpet into the paneling of the floorboard.
  6. Repair Loose Floorboard Carpet in Vehicle: paso 6, imagen 1 de 1
    • Vacuum floorboard to remove any debris or dirt.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 34
Ultimos 30 días: 143
Todo El Tiempo: 6,304
