Saltar al contenido principal
Removing a Solid-State Drive (SSD) From a PC
Qué necesitas
  1. Removing a Solid-State Drive (SSD) From a PC, Put on anti-shock wristband: paso 1, imagen 1 de 1
    • Put on the anti-shock wristband and connect the alligator clip to a large, grounded piece of metal.
    • Turn off the power supply on the back of the PC and disconnect all power cables.
  2. Removing a Solid-State Drive (SSD) From a PC, Remove panels: paso 2, imagen 1 de 2 Removing a Solid-State Drive (SSD) From a PC, Remove panels: paso 2, imagen 2 de 2
    • Remove the side panels of the PC case. Many cases are designed with a latch or large screws such that side panels can be removed without any tools.
    • For the case used in this guide, four screws on the back of the case must be removed, and the side panels slide towards the back to come free.
  3. Removing a Solid-State Drive (SSD) From a PC, Locate SSD: paso 3, imagen 1 de 2 Removing a Solid-State Drive (SSD) From a PC, Locate SSD: paso 3, imagen 2 de 2
    • Locate the SSD. In most cases, it will be mounted in a bay next to the motherboard.
    • Remove the screws holding the SSD in the bay.
  4. Removing a Solid-State Drive (SSD) From a PC, Remove SSD: paso 4, imagen 1 de 2 Removing a Solid-State Drive (SSD) From a PC, Remove SSD: paso 4, imagen 2 de 2
    • Gently slide the SSD out of its bay slot.
    • Unplug the two cables which are connected to the back of the SSD.
  5. Removing a Solid-State Drive (SSD) From a PC, Remove cables: paso 5, imagen 1 de 2 Removing a Solid-State Drive (SSD) From a PC, Remove cables: paso 5, imagen 2 de 2
    • The SSD is now removed, but there are two cables left in its place. One is a SATA cable, which can be identified by tracing it back to the mother board.
    • Find this connection and unplug the cable from the motherboard, then remove the cable from the PC.
  6. Removing a Solid-State Drive (SSD) From a PC, Remove and replace: paso 6, imagen 1 de 2 Removing a Solid-State Drive (SSD) From a PC, Remove and replace: paso 6, imagen 2 de 2
    • Trace the second cable, the power cable, back to the power supply unit.
    • If the cable can be removed from the power supply without removing any other cables, then the power supply is modular and the unused SSD cable can be safely removed.
    • If the power supply is not modular, tuck the unused SSD cable into space next to the power supply. Use a zip tie to secure it out of the way, if needed.
    • Slide the side panels of the case back into place, and secure with the appropriate screws as necessary. The solid-state drive has been successfully removed from the PC.
Conclusión
Una persona más ha completado esta guía.
Nguyen Nguyen
Miembro Desde 04/29/21
163 Reputación
1 Guía escrita
Un comentario
Geen uitleg hoe de ssd me2 van het moederboard te verwijderen. Ssd zit vlak onder de sleuf voor een externe video kaart gemonteerd op het moederboard met Intel.I7 processor. Gaarne uw oplossing
D. Kuipers - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 18
Ultimos 7 días: 113
Ultimos 30 días: 511
Todo El Tiempo: 14,501
