Saltar al contenido principal
Remover Pernos Allen con la cabeza pelada o zafada
Qué necesitas
  1. Remover Pernos Allen con la cabeza pelada o zafada, Remover Pernos Allen con la cabeza pelada o zafada: paso 1, imagen 1 de 1
    • Corta un zócalo en la cabeza del perno.
    • Coloca un destornillador en el zócalo y golpea con un martillo en el sentido contrario a las agujas del reloj para aflojar el perno.
    • Quita el perno con el destornillador.
Linea de Meta
44 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
en es
100%
¡ Gianfranco Sergi nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Wolfgang
Miembro Desde 02/17/12
597 Reputación
2 Guías creadas
6 comentarios
Use the same technique for Philips or crosshead screws.
Use a grinding / cutting disk, not a saw blade. Apply the rotating cutting disk gently, do not force or it will break.
If this is a toughened steel or stainless steel bolt (much tougher), it will be best to use a reinforced cutting disk.
Use a dusk mask to avoid breathing the dusk from the disk !
(No, I don't usually, but I should !)
Frank B - Contestar
While this works it is very difficult to not ruin the material around the bolt.
What I do is use a torx bit. size one up that is slightly larger then the hole and then firmly tap it in. atttach your drive handle a turn slowly while pushing down. this will normally break it free.
Also before your get to this point try putting your allen key in the hole and smack it with a hammer. sometimes the force of the hit will cause the metal to "break" enough that the allen screw wont strip.
Jamie Mcguire -
There are also specifically designed screw extractors made for this. These tools are generally two-sided: one side is used to drill the hole, while the other is inserted to extract. If the process works, the surrounding area is undamaged.
Karl Kaufmann - Contestar
Use another Allen bolt to weld over it and then you can easily remove the Allen bolt with the help of Allen key
Tushar Pednekar - Contestar
And if for any reason if you can't weld then just drill the head of the Allen bolt so it's shears off. And then u can easily remove the rest
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 19
Ultimos 7 días: 102
Ultimos 30 días: 476
Todo El Tiempo: 258,752
