Saltar al contenido principal
Remington MB4040 Battery Replacement
Qué necesitas
  1. Remington MB4040 Battery Replacement, Remove Blade Assembly: paso 1, imagen 1 de 3 Remington MB4040 Battery Replacement, Remove Blade Assembly: paso 1, imagen 2 de 3 Remington MB4040 Battery Replacement, Remove Blade Assembly: paso 1, imagen 3 de 3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Battery Replacement, Remove Back Cover Hardware: paso 2, imagen 1 de 2 Remington MB4040 Battery Replacement, Remove Back Cover Hardware: paso 2, imagen 2 de 2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Battery Replacement, Remove Front Cover Hardware: paso 3, imagen 1 de 3 Remington MB4040 Battery Replacement, Remove Front Cover Hardware: paso 3, imagen 2 de 3 Remington MB4040 Battery Replacement, Remove Front Cover Hardware: paso 3, imagen 3 de 3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Battery Replacement, Front Cover (cont.): paso 4, imagen 1 de 2 Remington MB4040 Battery Replacement, Front Cover (cont.): paso 4, imagen 2 de 2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Battery Replacement, Blade Button Removal: paso 5, imagen 1 de 2 Remington MB4040 Battery Replacement, Blade Button Removal: paso 5, imagen 2 de 2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Battery Replacement, Remove Motherboard: paso 6, imagen 1 de 2 Remington MB4040 Battery Replacement, Remove Motherboard: paso 6, imagen 2 de 2
    • Remove the four 9.0 mm PH00 screws from the motherboard.
    • Use the plastic opening tool to remove the motherboard from its housing.
    • This can be completed with the Remington MB4040 Zoom Wheel Replacement installed or removed. Just adjust the zoom wheel until it no longer covers the motherboard.
  7. Remington MB4040 Battery Replacement, Remove Battery: paso 7, imagen 1 de 3 Remington MB4040 Battery Replacement, Remove Battery: paso 7, imagen 2 de 3 Remington MB4040 Battery Replacement, Remove Battery: paso 7, imagen 3 de 3
    • Remove the thermal switch from the battery by using the spudger to pry it from the adhesive.
    • Remove the battery by desoldering the battery from the motherboard.
    • Soldering tabs hold the battery onto the motherboard.
Conclusión
22 personas más completaron esta guía.
Cameron Carnahan
Miembro Desde 01/20/15
1,067 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 1-5, Blackwell Winter 2015 Miembro de USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Miembros
7 Guías creadas
13 comentarios
Great work - but help on where to source the battery would be good too :)
Matt Purnell - Contestar
It's available as a generic - it's a '14500' Li-Ion battery, 3.7V - typically 750-800mAh. Dimensions: 50mm x 14mm (diameter).
I have seen two types of these batteries: protected and unprotected. Which type do we need?
Amaury C -
You did everyrhing except the most important part to me
How did you unsolder the battery, and solder the new battery?
I was going to buy the tools from the local store but realized i don't know how to appropriately unsolder/solder battery tabs.
Non the less you are the only one who made such explanation, thank you.
Rakan - Contestar
If you happen to lose the two springs, you can cut off 2 pieces from the spring of a pen :P
Merry Trimming & A Happy New Beard !
Mads Larsen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 45
Ultimos 30 días: 267
Todo El Tiempo: 35,742
