Saltar al contenido principal
Radiator/thermostat valve repair
Qué necesitas
  1. Radiator/thermostat valve repair, Radiator-/thermostat-valve: paso 1, imagen 1 de 1
    • Fully open the thermostat/valve
  2. Radiator/thermostat valve repair: paso 2, imagen 1 de 1
    • Undo the screw on the fastening clamp. In this case an older thermostat is shown. Newer models probably have a twist and screw cap and you may not need tools at all.
    • Remove the thermostat head.
  3. Radiator/thermostat valve repair: paso 3, imagen 1 de 1
    • Put some multipurpose oil onto the little transmission pin.
  4. Radiator/thermostat valve repair: paso 4, imagen 1 de 1
    • By tapping the pin CAREFULLY with a hammer, you can make it move again.
  5. Radiator/thermostat valve repair: paso 5, imagen 1 de 2 Radiator/thermostat valve repair: paso 5, imagen 2 de 2
    • Add some additional lubrication to the pin before screwing the thermostat back on.
    • By pushing the pin in and let it come back out several times using the hammer again, the oil should evenly distribute on the pin, so that in future it is very unlikely, that it is seizing up soon again.
    • That's it! Put the valve/thermostat back on and fix it in place.
Conclusión
To reassemble your device, follow the steps in reverse order.
4 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Martin Herterich
Miembro Desde 01/08/20
241 Reputación
1 Guía escrita
Equipo
iFixit EU Team Miembro de iFixit EU Team
Staff
46 Miembros
1,095 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 33
Ultimos 30 días: 226
Todo El Tiempo: 2,663
