Saltar al contenido principal
QSEW QS-1201 Needle Replacement
Qué necesitas
  1. QSEW QS-1201 Needle Replacement, Needle: paso 1, imagen 1 de 3 QSEW QS-1201 Needle Replacement, Needle: paso 1, imagen 2 de 3 QSEW QS-1201 Needle Replacement, Needle: paso 1, imagen 3 de 3
    • Power off your machine and unplug it from the outlet.
    • This will prevent accidental activation and injury, even for experts!
  2. QSEW QS-1201 Needle Replacement: paso 2, imagen 1 de 2 QSEW QS-1201 Needle Replacement: paso 2, imagen 2 de 2
    • Have a close look at the difference between the broken needle ( left ) and the brand-new needle ( right ).
  3. QSEW QS-1201 Needle Replacement: paso 3, imagen 1 de 3 QSEW QS-1201 Needle Replacement: paso 3, imagen 2 de 3 QSEW QS-1201 Needle Replacement: paso 3, imagen 3 de 3
    • Locate the needle holder with the broken needle.
  4. QSEW QS-1201 Needle Replacement: paso 4, imagen 1 de 3 QSEW QS-1201 Needle Replacement: paso 4, imagen 2 de 3 QSEW QS-1201 Needle Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
  5. QSEW QS-1201 Needle Replacement: paso 5, imagen 1 de 3 QSEW QS-1201 Needle Replacement: paso 5, imagen 2 de 3 QSEW QS-1201 Needle Replacement: paso 5, imagen 3 de 3
    • Gently secure the needle with the needle nose pliers.
    • With a tight grip, pull down to remove the needle.
  6. QSEW QS-1201 Needle Replacement: paso 6, imagen 1 de 3 QSEW QS-1201 Needle Replacement: paso 6, imagen 2 de 3 QSEW QS-1201 Needle Replacement: paso 6, imagen 3 de 3
    • Discard the broken needle in a safe place.
    • By doing so, you ensure that no one gets injured when dealing with the trash.
    • Afterward, use the needle nose pliers to insert the new needle into the needle holder securely.
  7. QSEW QS-1201 Needle Replacement: paso 7, imagen 1 de 3 QSEW QS-1201 Needle Replacement: paso 7, imagen 2 de 3 QSEW QS-1201 Needle Replacement: paso 7, imagen 3 de 3
    • Use the 3 mm Flathead screwdriver to secure the screw, without over-tightening.
  8. QSEW QS-1201 Needle Replacement: paso 8, imagen 1 de 3 QSEW QS-1201 Needle Replacement: paso 8, imagen 2 de 3 QSEW QS-1201 Needle Replacement: paso 8, imagen 3 de 3
    • Move the needle using the pliers in a circular motion from left to right to verify it moves freely without hitting any surrounding components.
    • You're all set to use your embroidery machine!
Conclusión
Reema
Miembro Desde 09/10/23
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 35
Todo El Tiempo: 143
