Saltar al contenido principal
PowerLead Puto PLD003 Tripod Clip Replacement
Qué necesitas
  1. PowerLead Puto PLD003 Tripod Clip Replacement, Side Panel: paso 1, imagen 1 de 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Tripod Clip Replacement: paso 2, imagen 1 de 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Tripod Clip Replacement: paso 3, imagen 1 de 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Tripod Clip Replacement: paso 4, imagen 1 de 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: paso 5, imagen 1 de 2 PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: paso 5, imagen 2 de 2
    • Apply pressure upwards to remove the tripod clip.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 144
