Saltar al contenido principal
Philips Steam Iron GC 1905 Power Cord Replacement
Qué necesitas
  1. Philips Steam Iron GC 1905 Power Cord Replacement, Power cord replacement: paso 1, imagen 1 de 1
    • Switch off and unplug the iron. Drain the water from the water tank.
    • To prevent damage to the soleplate of the iron, make sure the worktop surface is non-abrasive.
    • Make sure the iron has cooled down before you start disassembly.
  2. Philips Steam Iron GC 1905 Power Cord Replacement: paso 2, imagen 1 de 2 Philips Steam Iron GC 1905 Power Cord Replacement: paso 2, imagen 2 de 2
    • Turn over to the triangular backplate of the steam iron.
    • Remove the 10.0 mm screw securing the backplate to the main body with a Phillips #1 screwdriver.
  3. Philips Steam Iron GC 1905 Power Cord Replacement: paso 3, imagen 1 de 3 Philips Steam Iron GC 1905 Power Cord Replacement: paso 3, imagen 2 de 3 Philips Steam Iron GC 1905 Power Cord Replacement: paso 3, imagen 3 de 3
    • Wedge your thumb and fingers at the joint between the backplate and the handle to loosen the snap joints.
    • Be mindful of the snap joints as they may break if excess pressure is applied.
    • We advise against use of screwdriver to pry open the backplate as it may damage snap joints.
    • Pull out the backplate gently to reveal the electric circuit—it will be still be connected to the wires so don't yank it off.
    • Take a photo of the electrical circuit to use as reference in step 5.
  4. Philips Steam Iron GC 1905 Power Cord Replacement: paso 4, imagen 1 de 3 Philips Steam Iron GC 1905 Power Cord Replacement: paso 4, imagen 2 de 3 Philips Steam Iron GC 1905 Power Cord Replacement: paso 4, imagen 3 de 3
    • Grip the green cable as close to the crimp connector as possible.
    • For easy removal, pinch the crimp connector between your thumb and forefinger. Apply force to the connector rather than the cable.
    • Slide out the crimp connector attached to the cable.
    • Applying force to the cable might separate the wire from the connector and leave the crimp connector in the slot.
    • Repeat the previous step to remove the red and black cables and take out the power cord.
  5. Philips Steam Iron GC 1905 Power Cord Replacement: paso 5, imagen 1 de 3 Philips Steam Iron GC 1905 Power Cord Replacement: paso 5, imagen 2 de 3 Philips Steam Iron GC 1905 Power Cord Replacement: paso 5, imagen 3 de 3
    • To connect the new cables, align and slide the crimp connector on the green cable into vacant slot.
    • Repeat the above step for the red and black cables.
    • Make sure the green, red and black cables are inserted in the correct slots.
  6. Philips Steam Iron GC 1905 Power Cord Replacement: paso 6, imagen 1 de 1
    • Before reassembly, ensure that the cord does not obstruct the screw slot.
Conclusión
Happy Fixing!
5 personas más completaron esta guía.
Equipo
2 comentarios
het l'ange deksel was al door mij losgemaakt
2 klips in het midden ...kon niet verder Los krijgen
wat moet ik verser doen zonder stukken te maken stroomdraad is stuk ????
QUISQUATER ETIENNE - Contestar
But where do I find new wire online
Bharath Reddy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 48
Ultimos 30 días: 195
Todo El Tiempo: 6,537
