Saltar al contenido principal
Philips Satinelle On/Off Switch Replacement
Qué necesitas
  1. Philips Satinelle On/Off Switch Replacement, Plastic Cover: paso 1, imagen 1 de 3 Philips Satinelle On/Off Switch Replacement, Plastic Cover: paso 1, imagen 2 de 3 Philips Satinelle On/Off Switch Replacement, Plastic Cover: paso 1, imagen 3 de 3
    • Remove the head by pushing it to the right.
  2. Philips Satinelle On/Off Switch Replacement: paso 2, imagen 1 de 2 Philips Satinelle On/Off Switch Replacement: paso 2, imagen 2 de 2
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle On/Off Switch Replacement: paso 3, imagen 1 de 1
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
  4. Philips Satinelle On/Off Switch Replacement, On/Off Switch: paso 4, imagen 1 de 1
    • Remove the green board and the black socket.
  5. Philips Satinelle On/Off Switch Replacement: paso 5, imagen 1 de 1
    • Slide the switch down toward the socket.
  6. Philips Satinelle On/Off Switch Replacement: paso 6, imagen 1 de 3 Philips Satinelle On/Off Switch Replacement: paso 6, imagen 2 de 3 Philips Satinelle On/Off Switch Replacement: paso 6, imagen 3 de 3
    • Put the components back into the frame
    • If the switch won't line up with the plastic square, make sure the large switch on the front of the operator is in the "off" position.
Conclusión
Una persona más ha completado esta guía.
Riannon Varney
Miembro Desde 10/08/18
168 Reputación
1 Guía escrita
Equipo
Marist, Team S1-G1, Chaterdon Fall 2018 Miembro de Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
3 Miembros
4 Guías creadas
Un comentario
Very precise instructions, thanks!
carlos - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 53
Todo El Tiempo: 1,488
