Saltar al contenido principal
Pentax PZ-10 Back Cover Locking Switch Spring Replacement
Qué necesitas
  1. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Bottom Cover: paso 1, imagen 1 de 1
    • With the lens face up and the bottom panel of the camera facing you, remove the two 7mm screws on the left using the J0 screwdriver.
    • Remove the six 4.3mm screws in the middle and right of the panel using the J0 screwdriver.
    • Pull off the bottom casing to remove.
  2. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing Bottom Casing: paso 2, imagen 1 de 1
    • With the screws removed, the bottom casing should come off very easily by pulling on the casing.
  3. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Back Cover: paso 3, imagen 1 de 1
    • Place the camera on its side so the lens is facing left.
    • Press down on the locking switch on the side panel facing you.
  4. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: paso 4, imagen 1 de 1
    • With the door unlocked, rotate the device to access the bottom.
  5. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using a pair of tweezers, gently remove the metal tab securing the back door axle.
    • The door will come loose at this point, watch for any loose parts that may also come out.
  6. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Side Panel: paso 6, imagen 1 de 1
    • Once the back cover is fully removed, remove the two 4.35mm screws attaching the cover of the unlocking switch, and remove the plate.
  7. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Spring: paso 7, imagen 1 de 1
    • Locate the spring at the upper left corner of the face, and pull the rings of the spring off of the pins to remove it using plastic opening tools.
    • You are now ready to replace the spring.
Conclusión
Una persona más ha completado esta guía.
Ryan Su
Miembro Desde 04/20/15
107 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 430
