Saltar al contenido principal
Panasonic Lumix DMC-ZS25 Screen Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: paso 1, imagen 1 de 3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: paso 1, imagen 2 de 3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Screen Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to open the outer cover of your device from the HDMI port.
    • Open it carefully to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Screen Replacement: paso 3, imagen 1 de 3 Panasonic Lumix DMC-ZS25  Screen Replacement: paso 3, imagen 2 de 3 Panasonic Lumix DMC-ZS25  Screen Replacement: paso 3, imagen 3 de 3
    • Use a spudger to carefully detach the ribbon cable without breaking it.
  4. Panasonic Lumix DMC-ZS25  Screen Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool to lift and remove the buttons board as shown.
  5. Panasonic Lumix DMC-ZS25  Screen Replacement: paso 5, imagen 1 de 2 Panasonic Lumix DMC-ZS25  Screen Replacement: paso 5, imagen 2 de 2
    • Carefully lift the screen using the plastic opening tool as shown.
Conclusión
3 personas más completaron esta guía.
Abbas Khan
Miembro Desde 01/21/15
482 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 9-5, Brown Winter 2015 Miembro de USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Miembros
7 Guías creadas
Un comentario
- Of the two 2.60 mm screws on the bottom of the camera, only the one closest to the back needs to be removed.
- The correct screwdriver is JIS Type S #00. A Phillips driver can ruin the screws.
- The screen shown in step 5 consists of two parts: the LCD and a frame. The replacement LCD that I ordered came without the frame, so a little more disassembly was required, including a bit of delicate soldering: the narrow ribbon cable is really two cables, soldered together. The solder joints are hidden under the piece of black electric tape at the end.
nasorenga - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 4,383
