Saltar al contenido principal
Panasonic Camera DMC-FX07 Battery Replacement
  1. Panasonic Camera DMC-FX07 Battery Replacement, Battery: paso 1, imagen 1 de 2 Panasonic Camera DMC-FX07 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • The first step is to turn off the camera
    • Next, locate the battery door on the bottom of the camera
    • To open, slide the latch left, or towards the tripod mount
    • The door should spring open
  2. Panasonic Camera DMC-FX07 Battery Replacement: paso 2, imagen 1 de 3 Panasonic Camera DMC-FX07 Battery Replacement: paso 2, imagen 2 de 3 Panasonic Camera DMC-FX07 Battery Replacement: paso 2, imagen 3 de 3
    • Now that the door is open, release the spring clip on the right
    • The battery should pop out just enough so you can pull it out
    • Pull the battery out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 980
