Saltar al contenido principal
Olympus VR-350 Power Button Replacement
Qué necesitas
  1. Olympus VR-350 Power Button Replacement, Front Plate: paso 1, imagen 1 de 2 Olympus VR-350 Power Button Replacement, Front Plate: paso 1, imagen 2 de 2
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Power Button Replacement: paso 2, imagen 1 de 1
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Power Button Replacement: paso 3, imagen 1 de 3 Olympus VR-350 Power Button Replacement: paso 3, imagen 2 de 3 Olympus VR-350 Power Button Replacement: paso 3, imagen 3 de 3
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Power Button Replacement, Back Plate: paso 4, imagen 1 de 2 Olympus VR-350 Power Button Replacement, Back Plate: paso 4, imagen 2 de 2
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Olympus VR-350 Power Button Replacement, Power Button: paso 5, imagen 1 de 2 Olympus VR-350 Power Button Replacement, Power Button: paso 5, imagen 2 de 2
    • Remove the silver panel from the top of the camera.
  6. Olympus VR-350 Power Button Replacement: paso 6, imagen 1 de 1
    • Flip the silver panel over. The power button is the smaller button covered by a metal backing.
  7. Olympus VR-350 Power Button Replacement: paso 7, imagen 1 de 1
    • Pull the metal backing away from the silver panel.
  8. Olympus VR-350 Power Button Replacement: paso 8, imagen 1 de 1
    • Push the power button down and out of the silver panel with your finger.
Conclusión
2 personas más completaron esta guía.
Adri
Miembro Desde 02/23/15
456 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-3, Leahy Winter 2015 Miembro de USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 1,371
