Saltar al contenido principal
Olympus Stylus 1030 SW Motherboard Replacement
Qué necesitas
  1. Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: paso 1, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: paso 1, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: paso 1, imagen 3 de 3
    • Using the iFixit Opening Tool, pry off the plastic part of the lens.
    • Using the T6 Torx screwdriver, unscrew the three screws.
  2. Olympus Stylus 1030 SW Motherboard Replacement: paso 2, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 2, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using the Phillips #00 screwdriver, unscrew the three screws.
    • Carefully swivel the metal cover out towards you.
    • Using tweezers, remove the metal washer.
  3. Olympus Stylus 1030 SW Motherboard Replacement: paso 3, imagen 1 de 2 Olympus Stylus 1030 SW Motherboard Replacement: paso 3, imagen 2 de 2
    • Using the tweezers, slowly peel off the plate.
  4. Olympus Stylus 1030 SW Motherboard Replacement: paso 4, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 4, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 4, imagen 3 de 3
    • Using the Phillips #00 screwdriver, unscrew the two screws on the side of the camera.
  5. Olympus Stylus 1030 SW Motherboard Replacement: paso 5, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 5, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 5, imagen 3 de 3
    • On the opposite side, use the Phillips #00 screwdriver to unscrew both screws.
    • Take out the speaker plate.
    • Open the multi-connector cover and slide off the side panel.
  6. Olympus Stylus 1030 SW Motherboard Replacement: paso 6, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 6, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 6, imagen 3 de 3
    • Using the Phillips #00 screwdriver, unscrew the screw above the speaker.
    • On the bottom side of the camera, unscrew the two screws.
  7. Olympus Stylus 1030 SW Motherboard Replacement: paso 7, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 7, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 7, imagen 3 de 3
    • Open the battery compartment cover.
    • Use the Phillips #00 screwdriver to unscrew the screw in the battery compartment.
  8. Olympus Stylus 1030 SW Motherboard Replacement: paso 8, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 8, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 8, imagen 3 de 3
    • On the front of the camera, unscrew the two screws shown.
    • Gently pull on the side until the camera is separated from the back panel.
    • Remove the shutter and power button.
  9. Olympus Stylus 1030 SW Motherboard Replacement: paso 9, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 9, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 9, imagen 3 de 3
    • Use the Phillips #00 screwdriver to unscrew the four screws on the front of the camera.
    • Unscrew the shutter using the Phillips #00 screwdriver.
  10. Olympus Stylus 1030 SW Motherboard Replacement: paso 10, imagen 1 de 2 Olympus Stylus 1030 SW Motherboard Replacement: paso 10, imagen 2 de 2
    • Release the top holding using a spudger.
    • Slowly and carefully separate the front and back of the camera, exposing the electrical ribbons.
  11. Olympus Stylus 1030 SW Motherboard Replacement: paso 11, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 11, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 11, imagen 3 de 3
    • Using the spudger and tweezers if needed, remove the ribbons from the computer chips.
  12. Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: paso 12, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: paso 12, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: paso 12, imagen 3 de 3
    • Remove the 1.0 cm and the 0.8 mm screws.
    • Peel off tape and remove ribbons.
    • Remove black plastic cover and unscrew the 1.1 cm screw.
  13. Olympus Stylus 1030 SW Motherboard Replacement: paso 13, imagen 1 de 2 Olympus Stylus 1030 SW Motherboard Replacement: paso 13, imagen 2 de 2
    Comprar
    • Release ribbons carefully using either tweezers or a spudger.
    • Remove the 1.1 cm screw.
  14. Olympus Stylus 1030 SW Motherboard Replacement: paso 14, imagen 1 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 14, imagen 2 de 3 Olympus Stylus 1030 SW Motherboard Replacement: paso 14, imagen 3 de 3
    • Push A/V port away from you carefully using a spudger.
    • Slowly take out the motherboard and the speaker microphone.
    • Collect the metal washer plate from the top right corner of the motherboard (now loose).
  15. Olympus Stylus 1030 SW Motherboard Replacement: paso 15, imagen 1 de 2 Olympus Stylus 1030 SW Motherboard Replacement: paso 15, imagen 2 de 2
    • With a spudger or finger, slowly take out the battery hinged to the motherboard.
    • Be careful not to disconnect the wires by pulling it too hard.
    • Take out motherboard.
Conclusión
Una persona más ha completado esta guía.
3 comentarios
what is the voltage, and capacitance of the main flash capacitor? diameter and length? I want to replace mine as my 'flash charging' symbol constantly flashes and flash does not fire.
thanks for the writeup! I have more confidence in repairing my 10+ year old camera
Kevin Kay - Contestar
the cap is 330uF and 90V
dimensions:
11.94mm diameter
25.65mm length
How would I go about extracting the camera module and hooking it up to an arduino?
My cam got saltwater damage however it still turns on for a few seconds before turning off again
GoodNight Tea - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,113
