Saltar al contenido principal
Olympus SP-320 Motherboard Replacement
Qué necesitas
  1. Olympus SP-320 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Olympus SP-320 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Olympus SP-320 Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove the 3 mm long screws using a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the 3 mm long screw using a Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Motherboard Replacement: paso 3, imagen 1 de 2 Olympus SP-320 Motherboard Replacement: paso 3, imagen 2 de 2
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Motherboard Replacement: paso 4, imagen 1 de 3 Olympus SP-320 Motherboard Replacement: paso 4, imagen 2 de 3 Olympus SP-320 Motherboard Replacement: paso 4, imagen 3 de 3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, white, plastic clip detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Motherboard Replacement: paso 5, imagen 1 de 2 Olympus SP-320 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove 2 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
    • Remove 3 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
  6. Olympus SP-320 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove motherboard.
Conclusión
2 personas más completaron esta guía.
2 comentarios
Nice description to follow!
Would you know which component is responsible in SP-320 for keeping the date/time while battery is out ?
Every time I remove the battery for replacement, the date/time settings is gone (instantly). Thanks!
Istvan Ujfalvi - Contestar
It would be nice to know why you needed to access the motherboard.
John - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 523
