Saltar al contenido principal
Necklace Chain Repair
Qué necesitas
  1. Necklace Chain Repair, Necklace Chain Repair: paso 1, imagen 1 de 1
    • Look closely at where the necklace chain came apart. You will see a split ring, otherwise known as a jump ring.
    • Figure A: The jump ring is located on one end of the necklace.
  2. Necklace Chain Repair: paso 2, imagen 1 de 2 Necklace Chain Repair: paso 2, imagen 2 de 2
    • Figures B and C: While holding the needle nose pliers in one hand, clamp onto one end of the jump ring and hold on to the other end with your thumb and index finger.
    • Carefully pull on the ends of the jump ring until the opening is large enough to accommodate one of the chain links.
    • Warning: Do not separate the jump ring ends too far apart, otherwise damage to the jump ring may occur.
  3. Necklace Chain Repair: paso 3, imagen 1 de 2 Necklace Chain Repair: paso 3, imagen 2 de 2
    • Now that the jump ring opening is separated, you can reattach the chain. Find the end of the chain that had detached from the necklace.
    • Figures D and E: While holding the jump ring in one hand and the end of the necklace in your other hand, proceed to loop the chain into the opened jump ring.
  4. Necklace Chain Repair: paso 4, imagen 1 de 1
    • Figure F: Using similar methods from Step 2 Figure C, clamp onto one end of the jump ring slit with your pliers and hold on to the other end with your thumb and index finger.
    • Carefully close the opening of the jump ring.
  5. Necklace Chain Repair: paso 5, imagen 1 de 2 Necklace Chain Repair: paso 5, imagen 2 de 2
    • Figure G: It is time to close the jump ring. With your pliers, clamp on both ends of the jump ring and push together so the two ends of the jump ring slightly overlap.
    • Refer to Figure H for finished assembly.
Conclusión
To make sure the necklace is correctly reattached, gently pull on the chain. The jump ring should be firmly closed as to prevent the chain from slipping off the jump ring.
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 28-4, Green Spring 2015 Miembro de Cal Poly, Team 28-4, Green Spring 2015
CPSU-GREEN-S15S28G4
6 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 55
Todo El Tiempo: 4,631
