Saltar al contenido principal
Katadyne Hiker Water Filter Cleaning
Qué necesitas
  1. Katadyne Hiker Water Filter Cleaning, Katadyne Hiker Water Filter Cleaning: paso 1, imagen 1 de 1
    • Remove the "snap fit" guard by pulling directly away from the filter body.
  2. Katadyne Hiker Water Filter Cleaning: paso 2, imagen 1 de 1
    • Remove the pump handle by pulling it completely out of the shaft.
  3. Katadyne Hiker Water Filter Cleaning: paso 3, imagen 1 de 3 Katadyne Hiker Water Filter Cleaning: paso 3, imagen 2 de 3 Katadyne Hiker Water Filter Cleaning: paso 3, imagen 3 de 3
    • Use the pump handle to remove the filter cap.
    • Place the horizontal groove of the pump handle depicted in image 1 onto the filter fins.
    • Press the pump handle firmly against the fins and turn the filter counter clockwise.
    • Once unscrewed, remove the filter completely from the body.
  4. Katadyne Hiker Water Filter Cleaning: paso 4, imagen 1 de 3 Katadyne Hiker Water Filter Cleaning: paso 4, imagen 2 de 3 Katadyne Hiker Water Filter Cleaning: paso 4, imagen 3 de 3
    • Only perform this step if solid particles are evident on the outside of the filter.
    • Lightly brush the entire filter with a soft bristled toothbrush under running water.
  5. Katadyne Hiker Water Filter Cleaning: paso 5, imagen 1 de 1
    • Replace the filter inside the filter body and screw clockwise until tight.
  6. Katadyne Hiker Water Filter Cleaning: paso 6, imagen 1 de 1
    • Lubricate the pump handle O-ring extensively with the Katadyne lubricant (sold with pump).
  7. Katadyne Hiker Water Filter Cleaning: paso 7, imagen 1 de 1
    • Replace the pump handle inside the pump handle shaft.
  8. Katadyne Hiker Water Filter Cleaning: paso 8, imagen 1 de 2 Katadyne Hiker Water Filter Cleaning: paso 8, imagen 2 de 2
    • Replace the "snap-fit" guard by pushing directly toward the filter body.
Conclusión
If difficulty pumping persists, a new filter is required.
Una persona más ha completado esta guía.
Dylan Carey
Miembro Desde 02/24/15
130 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 24-6, Green Winter 2015 Miembro de Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Miembros
15 Guías creadas
Un comentario
wow. this is very helpful post.
thanks for nice guide line..
plz cheak out this—https://waterfilterhub.com
Kenny J. Jackson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 35
Todo El Tiempo: 723
