Saltar al contenido principal
Irulu walknbook Windows 10 tablet battery Replacement
Qué necesitas
  1. Irulu walknbook Windows 10 tablet  battery Replacement, battery: paso 1, imagen 1 de 1
    • this is what you should end up like with the tab
  2. Irulu walknbook Windows 10 tablet  battery Replacement: paso 2, imagen 1 de 1
    • first remove the orange (or other colour) bezels from the side of the tab. the all have a small hole grip.
  3. Irulu walknbook Windows 10 tablet  battery Replacement: paso 3, imagen 1 de 1
    • on the back cover there is a glass cover that covers up the screws. be carefull when removing it because it might break. use small like credit cards to seperate it but still be very carefull.
  4. Irulu walknbook Windows 10 tablet  battery Replacement: paso 4, imagen 1 de 1
    • so the back cover seperates in to two parts. after removing the glass part the screws are visible. remove all of them. the back cover can pe removed very easily.
  5. Irulu walknbook Windows 10 tablet  battery Replacement: paso 5, imagen 1 de 1
    • you then end up with all the rest of the internal parts visible. now you can replace the battery or the display. there is also a 3g port slot but i haven't tried it out yet. let me know if this worked for you.
Conclusión
6 personas más completaron esta guía.
Dili
Miembro Desde 08/29/15
242 Reputación
1 Guía escrita
11 comentarios
Hey I have another question is it possible to replace the ram in it or no
jackroc21 - Contestar
No that is not possible because the ram is soldered on the main board.
Dili -
where can I buy a replacement battery for this walknbook????
hushpuppy43 - Contestar
Donde puedo comprar la batería ,no la encuentro.
will5551970 - Contestar
Necesito comprar la batería para la irulu
Battery:7800 mAh irulu w1002
Donde la venden.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 5,621
