Saltar al contenido principal
Install macOS Printer Drivers
  1. Install macOS Printer Drivers, Install macOS Printer Drivers: paso 1, imagen 1 de 2 Install macOS Printer Drivers, Install macOS Printer Drivers: paso 1, imagen 2 de 2
    • Find the driver for your printer brand on the link below:
    • https://support.apple.com/kb/index?page=...
    • Download the driver for your printer, by clicking on the "Download" button.
    • If the message: "This connection is not private" appears, open the page with the private mode of your browser.
  2. Install macOS Printer Drivers: paso 2, imagen 1 de 2 Install macOS Printer Drivers: paso 2, imagen 2 de 2
    • Open your .dmg file
    • Open your .pkg file
    • If this message appears: "This update requires macOS 12.0 or earlier." click Close and continue with the next step.
    • Otherwise, continue with step 7.
  3. Install macOS Printer Drivers: paso 3, imagen 1 de 3 Install macOS Printer Drivers: paso 3, imagen 2 de 3 Install macOS Printer Drivers: paso 3, imagen 3 de 3
    • Move your .pkg file to your desktop
    • Open Terminal
    • Enter: cd Desktop/ then press the Enter key
  4. Install macOS Printer Drivers: paso 4, imagen 1 de 3 Install macOS Printer Drivers: paso 4, imagen 2 de 3 Install macOS Printer Drivers: paso 4, imagen 3 de 3
    • Enter the following command: pkgutil --expand FileName.pkg FileName
    • Change FileName to the name of your file, in both places.
    • Then press the Enter key.
    • A folder with the file name appears on your desktop.
    • Open the folder.
  5. Install macOS Printer Drivers: paso 5, imagen 1 de 2 Install macOS Printer Drivers: paso 5, imagen 2 de 2
    • Open the Distribution file with TextEdit
    • Then change the number after (system.compareVersions(system.version.ProductVersion, '12.0')" to that of your macOS version or later.
    • Save the file and close it.
  6. Install macOS Printer Drivers: paso 6, imagen 1 de 2 Install macOS Printer Drivers: paso 6, imagen 2 de 2
    • Return to the Terminal
    • Enter the following command: pkgutil --flatten FileName FileName.pkg and press the Enter key.
    • Close theTerminal and open FileName.pkg on your desktop.
  7. Install macOS Printer Drivers: paso 7, imagen 1 de 1
    • Congratulations, you can proceed with the installation by following the steps one by one.
Conclusión
Congratulations, you made it!
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Anthony Fassler
Miembro Desde 02/26/15
6,477 Reputación
4 Guías creadas
Un comentario
Merci pour cet excellent tutoriel, j'ai récupéré le fonctionnement de mon ancienne imprimante HP sur mon Mac !
Bravo !!!
Cédric Trocellier - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 113
Todo El Tiempo: 2,054
