Saltar al contenido principal
Install Porsche Cayenne LED Switchback Side Marker Lights
Qué necesitas
  1. Install Porsche Cayenne LED Switchback Side Marker Lights, LED Switchback Side Marker Lights: paso 1, imagen 1 de 1
    • Turn the wheel inside
    • Remove the clips in the wheelbase to access the back of the side marker.
  2. Install Porsche Cayenne LED Switchback Side Marker Lights: paso 2, imagen 1 de 1
    • Remove the screw securing the stock amber side marker.
    • Remove amber side marker.
  3. Install Porsche Cayenne LED Switchback Side Marker Lights: paso 3, imagen 1 de 3 Install Porsche Cayenne LED Switchback Side Marker Lights: paso 3, imagen 2 de 3 Install Porsche Cayenne LED Switchback Side Marker Lights: paso 3, imagen 3 de 3
    • Unplug stock side marker.
    • Remove stock bulb.
    • Replace with new LED side marker.
  4. Install Porsche Cayenne LED Switchback Side Marker Lights: paso 4, imagen 1 de 1
    • Connect additional white wire to the ACC or Existing LED Daytime Running Lamp Positive
  5. Install Porsche Cayenne LED Switchback Side Marker Lights: paso 5, imagen 1 de 1
    • Test everything to check if everything works correctly.
    • Put all components back the same way it was removed.
  6. Install Porsche Cayenne LED Switchback Side Marker Lights: paso 6, imagen 1 de 2 Install Porsche Cayenne LED Switchback Side Marker Lights: paso 6, imagen 2 de 2
    • Enjoy the new Porsche Cayenne LED side marker lights.
Conclusión
You can see that the installation process is very straightforward. Your Porsche Cayenne is now extremely unique on the road with these switchback LED side marker lights!
3 personas más completaron esta guía.
Eric Wu
Miembro Desde 01/21/15
3,357 Reputación
23 Guías creadas
2 comentarios
can you tell us where you connected the white wire? it doesn’t show in the images. did you just tap the DRL wire nearby or run it to the fuse box?
Dan Vaz-Pocas - Contestar
There si an easier way to remove the lights - take apiece of fishing line and wrap it over the front and behind the light. Pull it towards the door and it will release the front catch and the light pops right out
Tom Turner - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 34
Todo El Tiempo: 3,746
