Saltar al contenido principal
How to jump start a 2010 Honda Insight
Qué necesitas
  1. How to jump start a 2010 Honda Insight, How to jump start a 2010 Honda Insight: paso 1, imagen 1 de 1
    • Make sure that both cars are turned off.
    • Pop open the hood of the Insight by pulling the lever located here:
  2. How to jump start a 2010 Honda Insight: paso 2, imagen 1 de 1
    • Open the hood by reaching under the hood (in the front and center) and pulling the lever.
  3. How to jump start a 2010 Honda Insight: paso 3, imagen 1 de 1
    • Lock open the hood by grabbing the rod and inserting it into the hole on the under side of the hood.
  4. How to jump start a 2010 Honda Insight: paso 4, imagen 1 de 1
    • Open the hood of the secondary car, and lock it up into place (with spring-action rod if necessary).
  5. How to jump start a 2010 Honda Insight: paso 5, imagen 1 de 1
    • Grab your jumper cables.
  6. How to jump start a 2010 Honda Insight: paso 6, imagen 1 de 1
    • Locate the battery in both the Honda Insight and the secondary car.
    • The battery always has a big red plastic part that will indicate the positive terminal.
  7. How to jump start a 2010 Honda Insight: paso 7, imagen 1 de 1
    • WARNING! DO NOT LET THE LEADS TOUCH EACH OTHER OR ANY OTHER METAL!
    • Attach the RED lead to the secondary car's battery where the positive (RED) terminal is.
  8. How to jump start a 2010 Honda Insight: paso 8, imagen 1 de 1
    • Attach the other RED lead to the positive (RED) terminal of the Honda Insight's battery.
  9. How to jump start a 2010 Honda Insight: paso 9, imagen 1 de 1
    • Attach the BLACK lead to the secondary car's battery where the negative terminal is.
  10. How to jump start a 2010 Honda Insight: paso 10, imagen 1 de 3 How to jump start a 2010 Honda Insight: paso 10, imagen 2 de 3 How to jump start a 2010 Honda Insight: paso 10, imagen 3 de 3
    • Attach the other BLACK lead to the grounding strap located here:
    • Do not connect the black lead to any other part of the car.
  11. How to jump start a 2010 Honda Insight: paso 11, imagen 1 de 1
    • Start the engine of the secondary car and let the engine run for 1-2 minutes.
  12. How to jump start a 2010 Honda Insight: paso 12, imagen 1 de 1
    • Start the engine of the Honda Insight and let it run for 2-3 minutes.
    • NOTE: If your Insight does not start at this point, let the battery charge for a few more minutes.
  13. How to jump start a 2010 Honda Insight: paso 13, imagen 1 de 1
    • After the Insight has successfully started and has been running for a few minutes, remove leads in reverse order of attachment.
    • WARNING: DO NOT LET THE LEADS TOUCH EACH OTHER OR ANY OTHER METAL!
    • It may appear in this photo that the battery cables are incorrectly hooked up to battery terminals on both vehicles. Make sure to follow the earlier instructions regarding using the grounding strap on the Insight instead.
  14. How to jump start a 2010 Honda Insight: paso 14, imagen 1 de 1
    • Drive the Insight for at least 30 minutes before turning it off again to ensure a full charge of your battery.
    • NOTE: You may also simply let the engine run for 30 minutes rather than driving.
Conclusión
If your car still does not run after all of this, call a mechanic because you may have a bigger problem than a dead battery.
2 personas más completaron esta guía.
Hannah Jackson
Miembro Desde 02/23/15
138 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 12-4, Green Winter 2015 Miembro de Cal Poly, Team 12-4, Green Winter 2015
CPSU-GREEN-W15S12G4
5 Miembros
9 Guías creadas
2 comentarios
Where should you clamp the black lead if using a portable jump starter and cable won't reach the grounding strap? Thanks!
missyunc - Contestar
When I start the engine, the alarm is going on. How to turn it off?
Eugenia Grosu - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 28
Ultimos 30 días: 112
Todo El Tiempo: 21,706
