Saltar al contenido principal
How to Sharpen a Shovel Blade
Qué necesitas
  1. How to Sharpen a Shovel Blade, How to Sharpen a Shovel Blade: paso 1, imagen 1 de 1
    • Use a wire brush to scrape away all dirt and debris from the shovel blade.
  2. How to Sharpen a Shovel Blade: paso 2, imagen 1 de 2 How to Sharpen a Shovel Blade: paso 2, imagen 2 de 2
    • Place the shovel facing up in the vice.
    • Turn the lever to lock the shovel in place.
    • Keep a firm grip on the shovel’s handle to keep your hands away from the clamp.
  3. How to Sharpen a Shovel Blade: paso 3, imagen 1 de 2 How to Sharpen a Shovel Blade: paso 3, imagen 2 de 2
    • Hold the metal file at a 45° angle.
    • Push the file forward against the shovel blade.
    • Be sure to wear safety gloves and safety goggles as you work with the metal blade.
  4. How to Sharpen a Shovel Blade: paso 4, imagen 1 de 1
    • Flip the shovel over.
    • Lock the shovel in place using the bench vice.
    • File down the backside of the blade to get rid of the burr.
  5. How to Sharpen a Shovel Blade: paso 5, imagen 1 de 1
    • Flip the shovel facing up one more time.
    • Lock the shovel in place using it he bench vice.
    • Gently file the blade facing up for one last cleaning.
Conclusión
To sharpen your shovel blade, follow these instructions in order but take your time throughout the process in order to avoid cutting injuries.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 29
Todo El Tiempo: 112
