Saltar al contenido principal
How to Reupholster a Bench Cushion
Qué necesitas
  1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: paso 1, imagen 1 de 3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: paso 1, imagen 2 de 3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: paso 1, imagen 3 de 3
    • Remove the base from the frame of the bench.
    • If the base is screwed on the frame, use a screwdriver or a drill to remove the screws.
  2. How to Reupholster a Bench Cushion: paso 2, imagen 1 de 3 How to Reupholster a Bench Cushion: paso 2, imagen 2 de 3 How to Reupholster a Bench Cushion: paso 2, imagen 3 de 3
    • Lift the staples with the flathead screwdriver before going in with the pliers.
  3. How to Reupholster a Bench Cushion: paso 3, imagen 1 de 3 How to Reupholster a Bench Cushion: paso 3, imagen 2 de 3 How to Reupholster a Bench Cushion: paso 3, imagen 3 de 3
    • Use a pair of pliers to grip the staples.
    • Twist and pull the staples to remove them from the bench.
  4. How to Reupholster a Bench Cushion: paso 4, imagen 1 de 3 How to Reupholster a Bench Cushion: paso 4, imagen 2 de 3 How to Reupholster a Bench Cushion: paso 4, imagen 3 de 3
    • Place clean material down so the new fabric does not get dirty.
    • Place the fabric with the design face down on top of the clean sheet.
    • Then place the cushion, then the base face down.
  5. How to Reupholster a Bench Cushion: paso 5, imagen 1 de 3 How to Reupholster a Bench Cushion: paso 5, imagen 2 de 3 How to Reupholster a Bench Cushion: paso 5, imagen 3 de 3
    • Keep the safety lock closed when not using the staple gun.
    • When ready to use the staple gun, pull the safety lock down.
    • Insert the staples into the stapler.
  6. How to Reupholster a Bench Cushion: paso 6, imagen 1 de 3 How to Reupholster a Bench Cushion: paso 6, imagen 2 de 3 How to Reupholster a Bench Cushion: paso 6, imagen 3 de 3
    • Pull the fabric taut and staple every 4 inches.
  7. How to Reupholster a Bench Cushion: paso 7, imagen 1 de 3 How to Reupholster a Bench Cushion: paso 7, imagen 2 de 3 How to Reupholster a Bench Cushion: paso 7, imagen 3 de 3
    • Fold the corners of the fabric inward then on top.
    • Staple the fabric down twice for each corner.
    • Cut the excess fabric along the shorter sides of the base length.
    • Place the base back onto the frame.
    • If any screws were removed, screw them back on.
Linea de Meta
2 personas más completaron esta guía.
Xochitl Vara
Miembro Desde 01/26/22
169 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 455
