Saltar al contenido principal
How to Restore a Dining Chair
Qué necesitas
  1. How to Restore a Dining Chair, How to Restore a Dining Chair: paso 1, imagen 1 de 3 How to Restore a Dining Chair, How to Restore a Dining Chair: paso 1, imagen 2 de 3 How to Restore a Dining Chair, How to Restore a Dining Chair: paso 1, imagen 3 de 3
    • Begin with an old chair frame.
    • For frames in good condition, continue to step 5.
    • Using your sandpaper, rub any marks or scuffs off the wood.
    • Always rub with the grain of the wood.
  2. How to Restore a Dining Chair: paso 2, imagen 1 de 2 How to Restore a Dining Chair: paso 2, imagen 2 de 2
    • Use the cleaning cloth to wipe off any excess dirt and dust.
  3. How to Restore a Dining Chair: paso 3, imagen 1 de 3 How to Restore a Dining Chair: paso 3, imagen 2 de 3 How to Restore a Dining Chair: paso 3, imagen 3 de 3
    • Holding the spray paint 6-12 inches away from the chair, apply a light coat of paint.
    • Allow it to dry for about 5 minutes.
    • Apply a second light coat over the front of the chair and allow it to dry for 10 minutes.
  4. How to Restore a Dining Chair: paso 4, imagen 1 de 2 How to Restore a Dining Chair: paso 4, imagen 2 de 2
    • Flip the chair over.
    • Repeat step 3 for the back side.
  5. How to Restore a Dining Chair: paso 5, imagen 1 de 3 How to Restore a Dining Chair: paso 5, imagen 2 de 3 How to Restore a Dining Chair: paso 5, imagen 3 de 3
    • While the paint dries, work on the seat.
    • Grab the wood board and set it down.
    • Grab the desired cushion and rest it on top of the board.
    • Make sure to align all four corners of the wood to the corners of the cushion.
  6. How to Restore a Dining Chair: paso 6, imagen 1 de 3 How to Restore a Dining Chair: paso 6, imagen 2 de 3 How to Restore a Dining Chair: paso 6, imagen 3 de 3
    • Now grab the cushion cover.
    • You may use fabric (cut to size) instead of a cushion cover.
    • Place your cover on top of the cushion, aligning all four corners.
  7. How to Restore a Dining Chair: paso 7, imagen 1 de 3 How to Restore a Dining Chair: paso 7, imagen 2 de 3 How to Restore a Dining Chair: paso 7, imagen 3 de 3
    • Grab the stack of wood, cushion and cover and flip it over.
    • Align them so they stack up evenly.
    • Fragments of the cushion cover may stick out a little.
  8. How to Restore a Dining Chair: paso 8, imagen 1 de 3 How to Restore a Dining Chair: paso 8, imagen 2 de 3 How to Restore a Dining Chair: paso 8, imagen 3 de 3
    • Fold the sides of the cover over the board and cushion keeping them as close to the center of the board as possible.
    • Select a side to start on.
    • With the staple gun, staple the end of the cushion cover you are holding into the board.
    • Rotate the board and staple down the other side.
    • Continue to staple down the sides, placing staples about 1 inch apart.
    • Fold the corners in and staple them onto the board.
  9. How to Restore a Dining Chair: paso 9, imagen 1 de 3 How to Restore a Dining Chair: paso 9, imagen 2 de 3 How to Restore a Dining Chair: paso 9, imagen 3 de 3
    • Make sure that the paint on the chair frame has completely dried up.
    • Grab your newly covered cushion and place it on the seat of the chair frame.
    • Holding on to both the cushion and the frame, flip the chair over.
  10. How to Restore a Dining Chair: paso 10, imagen 1 de 3 How to Restore a Dining Chair: paso 10, imagen 2 de 3 How to Restore a Dining Chair: paso 10, imagen 3 de 3
    • Place the screws in the screw holes.
    • Tighten the screws with the philips screw driver.
    • To avoid the wood from cracking, do not apply to much force when turning screwdriver.
  11. How to Restore a Dining Chair: paso 11, imagen 1 de 1
    • Make good use of your brand new chair.
Linea de Meta
3 personas más completaron esta guía.
Chuy Mercado
Miembro Desde 09/29/15
228 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-6, Green Fall 2015 Miembro de Cal Poly, Team 15-6, Green Fall 2015
CPSU-GREEN-F15S15G6
5 Miembros
4 Guías creadas
2 comentarios
Do you have any Ideas on fixing a wobble chair before replacing the seat ?
Robert - Contestar
Hi, I have a aoks chair I want to restore can you please help
Josefina Mejia - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 36
Todo El Tiempo: 6,555
