Saltar al contenido principal
How to Replace a Coffee Tabletop Glass
Qué necesitas
  1. How to Replace a Coffee Tabletop Glass, Coffee Table Glass: paso 1, imagen 1 de 2 How to Replace a Coffee Tabletop Glass, Coffee Table Glass: paso 1, imagen 2 de 2
    • Flip the coffee table base upside down on an empty area.
  2. How to Replace a Coffee Tabletop Glass: paso 2, imagen 1 de 1
    • Use a cleaning spray to clean the surface of the glass table.
    • Use gloves while cleaning the table. The glass cleaner spray may contain toxic chemicals.
  3. How to Replace a Coffee Tabletop Glass: paso 3, imagen 1 de 2 How to Replace a Coffee Tabletop Glass: paso 3, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove one 1/4 in.-20 x 1-1/2 in. socket cap screw from the side of the glass.
    • Repeat the process for the other 1/4 in.-20 x 1-1/2 in. socket cap screw.
    • The appearance of this screw may differ from table to table, but the procedure remains the same. Use the appropriate screwdriver to open the screws.
  4. How to Replace a Coffee Tabletop Glass: paso 4, imagen 1 de 2 How to Replace a Coffee Tabletop Glass: paso 4, imagen 2 de 2
    • Remove the coffee table legs piece by piece.
  5. How to Replace a Coffee Tabletop Glass: paso 5, imagen 1 de 1
    • Remove the glass.
    • Remember that glass can be shattered or partially damaged. Use gloves to avoid possible cuts.
  6. How to Replace a Coffee Tabletop Glass: paso 6, imagen 1 de 1
    • Replace the broken/ damaged glass with the new one.
Conclusión
Jasrin Kaur
Miembro Desde 05/10/21
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 50
Todo El Tiempo: 2,328
