Saltar al contenido principal
How to Replace Underside Fabric of a Chair
Qué necesitas
  1. How to Replace Underside Fabric of a Chair, Underside Fabric: paso 1, imagen 1 de 1
    • Turn the armchair on its back.
  2. How to Replace Underside Fabric of a Chair: paso 2, imagen 1 de 1
    • Use pliers to remove the staples from the chair frame.
    • If the staples are too difficult to remove, cut away the fabric with scissors.
  3. How to Replace Underside Fabric of a Chair: paso 3, imagen 1 de 1
    • Measure out the dimensions of the perimeter of the chair frame.
    • Add an extra inch to each side to allow for error.
  4. How to Replace Underside Fabric of a Chair: paso 4, imagen 1 de 2 How to Replace Underside Fabric of a Chair: paso 4, imagen 2 de 2
    • Trace the dimensions onto the new fabric.
    • Cut along the traced lines.
  5. How to Replace Underside Fabric of a Chair: paso 5, imagen 1 de 1
    • Fold under approximately a 1-inch allowance from the fabric’s edges.
    • Adjust the folded edges as needed to the correct size.
  6. How to Replace Underside Fabric of a Chair: paso 6, imagen 1 de 2 How to Replace Underside Fabric of a Chair: paso 6, imagen 2 de 2
    • Use a staple gun to staple the fabric to the chair frame starting at one corner.
    • If the staples do not go all the way into the chair frame, tap lightly with a hammer.
  7. How to Replace Underside Fabric of a Chair: paso 7, imagen 1 de 1
    • Sit the chair upright and make sure the fabric is not visible or sagging.
    • If the fabric is visible, remove the staples from the closest corner and pull taut.
Linea de Meta
3 personas más completaron esta guía.
Nicole Keller
Miembro Desde 06/09/16
294 Reputación
1 Guía escrita
Equipo
Texas Tech, Team 3-3, Rauch SU 2016 Miembro de Texas Tech, Team 3-3, Rauch SU 2016
TTU-RAUCH-SU16S3G3
2 Miembros
1 Guía escrita
2 comentarios
excellent ways to repair the home furniture. thanks for your ways of writing such a good article about furniture.
Nice post written by Nicole Keller.
http://www.birchi.in/kids-and-baby/kids-...
Birchi In - Contestar
Thanks a lot! Wish I knew this a couple of weeks ago. Instead, I went and bought two all new 1 seater sofas in Sydney,
Lucas Bergman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 43
Ultimos 30 días: 219
Todo El Tiempo: 22,236
