Saltar al contenido principal
How to Replace Concealed Cabinet Hinges
Qué necesitas
  1. How to Replace Concealed Cabinet Hinges, Hinge: paso 1, imagen 1 de 3 How to Replace Concealed Cabinet Hinges, Hinge: paso 1, imagen 2 de 3 How to Replace Concealed Cabinet Hinges, Hinge: paso 1, imagen 3 de 3
    • Remove the screws that are attached to the cabinet door.
    • Unscrew the top and bottom hinges even if you are only replacing one hinge.
    • Remove the cabinet door from the hinge.
    • You may need to wiggle or pry the door off.
  2. How to Replace Concealed Cabinet Hinges: paso 2, imagen 1 de 2 How to Replace Concealed Cabinet Hinges: paso 2, imagen 2 de 2
    • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
    • Only the hinge being replaced needs to be removed.
  3. How to Replace Concealed Cabinet Hinges: paso 3, imagen 1 de 3 How to Replace Concealed Cabinet Hinges: paso 3, imagen 2 de 3 How to Replace Concealed Cabinet Hinges: paso 3, imagen 3 de 3
    • Insert the new hinge into the cabinet door's pre-cut hole.
    • Attach the hinge with the provided screws.
    • To avoid striping the screws, do not over tighten.
  4. How to Replace Concealed Cabinet Hinges: paso 4, imagen 1 de 1
    • Reattach the cabinet door to the cabinet frame.
    • Do not tighten the screws all the way. You will need to align the door later.
    • You may need a friend to hold the door while you screw it back into place.
  5. How to Replace Concealed Cabinet Hinges: paso 5, imagen 1 de 2 How to Replace Concealed Cabinet Hinges: paso 5, imagen 2 de 2
    • Lift or lower the cabinet door to align the hinges with its original location.
    • Changes in wood stain can serve as a useful alignment guide.
    • Tighten all the screws.
  6. How to Replace Concealed Cabinet Hinges: paso 6, imagen 1 de 3 How to Replace Concealed Cabinet Hinges: paso 6, imagen 2 de 3 How to Replace Concealed Cabinet Hinges: paso 6, imagen 3 de 3
    • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
    • Loosen the adjustment screws, but do not remove them.
    • Slide the cabinet door to your desired position.
    • Tighten the screws.
  7. How to Replace Concealed Cabinet Hinges: paso 7, imagen 1 de 1
    • Use this step if your cabinet door closes too hard or does not completely close.
    • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
    • Do not completely remove this screw.
Linea de Meta
4 personas más completaron esta guía.
Naomi Frazier
Miembro Desde 04/28/17
171 Reputación
1 Guía escrita
Equipo
UC Davis, Team S4-G4, Cole Spring 2017 Miembro de UC Davis, Team S4-G4, Cole Spring 2017
UCD-COLE-S17S4G4
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 21
Ultimos 30 días: 111
Todo El Tiempo: 27,943
