Saltar al contenido principal
How to Repair the Hinges on a Sofa Storage Compartment
Qué necesitas
  1. How to Repair the Hinges on a Sofa Storage Compartment, Hinges: paso 1, imagen 1 de 2 How to Repair the Hinges on a Sofa Storage Compartment, Hinges: paso 1, imagen 2 de 2
    • Partially remove the inside fabric to access screw holes.
    • If the fabric is stapled down, you can use the Phillips screwdriver to loosen the staples. In this case, the fabric was already coming off so it was easy to pull back by hand.
  2. How to Repair the Hinges on a Sofa Storage Compartment: paso 2, imagen 1 de 2 How to Repair the Hinges on a Sofa Storage Compartment: paso 2, imagen 2 de 2
    • Apply glue to the match stick and insert it into the screw holes.
    • Depending on the size of the hole, you may need more than 1 match stick for each hole. Toothpicks will also work in place of a match stick.
  3. How to Repair the Hinges on a Sofa Storage Compartment: paso 3, imagen 1 de 2 How to Repair the Hinges on a Sofa Storage Compartment: paso 3, imagen 2 de 2
    • Break off the end of the match sticks and use a hammer to secure it in the holes
    • A gentle tap with the hammer is all you need to set the stick into the hole.
  4. How to Repair the Hinges on a Sofa Storage Compartment: paso 4, imagen 1 de 1
    • Use the staple gun to staple the inside fabric. Allow the glued match sticks to dry for approximately 5 minutes before doing the next step.
  5. How to Repair the Hinges on a Sofa Storage Compartment: paso 5, imagen 1 de 2 How to Repair the Hinges on a Sofa Storage Compartment: paso 5, imagen 2 de 2
    • Use a Phillips screwdriver to attach each hinge to the cover of the storage compartment with two ¾-inch Flat-Head Wood screws #9.
  6. How to Repair the Hinges on a Sofa Storage Compartment: paso 6, imagen 1 de 2 How to Repair the Hinges on a Sofa Storage Compartment: paso 6, imagen 2 de 2
    • Use a Phillips screwdriver to attach each hinge to the base of the storage compartment with four ¾-inch Flat-Head Wood screws #9.
  7. How to Repair the Hinges on a Sofa Storage Compartment: paso 7, imagen 1 de 1
    • Here is the Storage Compartment all back together and good as new!
Conclusión
After following this fast fix guide, the hinges should be tightly secured and storage compartment is fixed.
Karen Walters
Miembro Desde 06/28/21
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 56
Todo El Tiempo: 1,714
