Saltar al contenido principal
How to Repair a Small Hole in a Spanish Knife Textured Wall
Qué necesitas
  1. How to Repair a Small Hole in a Spanish Knife Textured Wall, How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 1, imagen 1 de 2 How to Repair a Small Hole in a Spanish Knife Textured Wall, How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 1, imagen 2 de 2
    • Remove any debris from the hole in the wall.
  2. How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 2, imagen 1 de 1
    • Scoop some DryDex Spackling on to your plastic taping knife.
  3. How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 3, imagen 1 de 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 3, imagen 2 de 2
    • Fill the hole with spackle.
  4. How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 4, imagen 1 de 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 4, imagen 2 de 2
    • Gently move the taping knife over the newly covered hole in multiple directions.
    • This will ensure the spackle completely fills the hole.
    • Let the DryDex Spackle dry.
    • You will know the spackle is dry when it turns from pink to white.
  5. How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 5, imagen 1 de 1
    • Sand the newly spackled area down until the spackle is level with the original wall.
  6. How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 6, imagen 1 de 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 6, imagen 2 de 2
    • Scoop some All Purpose Joint Compound on to your putty knife.
  7. How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 7, imagen 1 de 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 7, imagen 2 de 2
    • Smooth the joint compound on the wall, covering the area you want to re-texture.
  8. How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 8, imagen 1 de 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 8, imagen 2 de 2
    • Gently drag the putty knife through the joint compound to create ridges.
    • Creating ridges is a creative and unique process. You get to decide how close you want the ridges together and at what angle to make the ridges.
    • Let the joint compound completely dry.
    • You will know the Joint Compound is dry when it turns from grey to white.
  9. How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 9, imagen 1 de 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 9, imagen 2 de 2
    • Mix the paint that you have leftover from the first time you painted the wall.
  10. How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 10, imagen 1 de 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: paso 10, imagen 2 de 2
    • Paint the section of the wall that you re-textured.
    • Paint each ridge.
    • Let the paint completely dry.
Conclusión
You’ve successfully spackled, textured, and painted. Your wall is now as good as new!
Kayla Elder
Miembro Desde 09/22/21
198 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 44
Todo El Tiempo: 891
