Saltar al contenido principal
How to Repair a Silent Wall Clock Mechanism
Qué necesitas
  1. How to Repair a Silent Wall Clock Mechanism, How to Repair a Silent Wall Clock Mechanism: paso 1, imagen 1 de 1
    • Using a screwdriver, remove all the screws on the back of the clock.
  2. How to Repair a Silent Wall Clock Mechanism: paso 2, imagen 1 de 1
    • Use your fingers to pry up one end of the battery and remove it from the clock.
  3. How to Repair a Silent Wall Clock Mechanism: paso 3, imagen 1 de 1
    • Clean the battery terminals in the battery compartment using isopropyl alcohol and a cotton swab.
  4. How to Repair a Silent Wall Clock Mechanism: paso 4, imagen 1 de 1
    • Dry the battery terminals with a clean cloth or paper towels so the terminals are not wet when a new battery is being inserted.
  5. How to Repair a Silent Wall Clock Mechanism: paso 5, imagen 1 de 1
    • Once the terminals have dried up, remove the glass lens covering the faceplate of the clock to make any adjustments.
  6. How to Repair a Silent Wall Clock Mechanism: paso 6, imagen 1 de 1
    • Turn the display face up, ensuring the clock hands do not touch each other.
    • Correct the time by moving the hands of the clock and inserting the new battery.
  7. How to Repair a Silent Wall Clock Mechanism: paso 7, imagen 1 de 1
    • Put the faceplate back on and assemble all of the pieces of the clock.
Conclusión
5 personas más completaron esta guía.
Mohammad Kijera
Miembro Desde 02/01/22
250 Reputación
1 Guía escrita
Equipo
2 comentarios
catellano por favor.gracias.
mario oscar Fiori - Contestar
You don't need to open the clock to set the time - just turn that circle dial on the backside of the clock! What is this guide "fixing" anyway??
Ari - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 43
Ultimos 30 días: 186
Todo El Tiempo: 5,244
